BMW accessory adapter.
- Has thanked: 105 times
- Been thanked: 71 times
I'm hiring a BMW f800r while I'm on holiday at Christmas but I'm looking for an adapter to bring the cigarette lighter plug on my satnav down to the BMW sized socket.Can someone point me in the right direction,please. (thumbs)
- Moderator
- Has thanked: 27 times
- Been thanked: 74 times
Re: BMW accessory adapter.
Mine doesnt, R1100GS, bike has to be running, well key turned etc.
Currently an F650GS, DR350 and RV125 in the family stable.
The canbus (camus?) turns the socket off after turning the ignition off.moto al wrote:Just a point,dos that still change when the engine switched off . Re camping lights ,or charging ,phones,iPods etc. With the BMW Camus system.cheers Al
Run a fused fly lead straight off the battery with an Optimate style connector and make up a cigarette lighter socket to plugin. This way you can charge the battery off an Optimate with the canbus off and when camping plug in accessories for charge when the bike ignition is off.Nigel wrote:The canbus (camus?) turns the socket off after turning the ignition off.moto al wrote:Just a point,dos that still change when the engine switched off . Re camping lights ,or charging ,phones,iPods etc. With the BMW Camus system.cheers Al
Even better, buy one of those power bank chargers, and charge it on the bike via can bus using a cigarette socket fly lead converter to BMW socket available from Nippy Normans. Charge the bank while riding then charge devices while off the bike by leaving locked in panniers or top box. (thumbs)
My F650GS switches the socket off after 15 minutes to save the battery (thumbs)moto al wrote:Just a point,dos that still change when the engine switched off . Re camping lights ,or charging ,phones,iPods etc. With the BMW Camus system.cheers Al
I use the Optimate solution as well (thumbs)
The charging lead direct to the battery is dead useful for rotating charging in the garage -
And you can get a selection of accessory leads from Optimate now - including USB chargers, lights etc.
