950 adv head wobble
Mike101
950 adv head wobble
Post by Mike101 » Mon May 11, 2015 12:09 pm
Yes folks I know this is a common problem but what is your like and what have you done to fix it.
Mine give a violent bar shake when slowing down from 50 to 35..worst around 45mph.
I've just out new steering bearings in so everything is much smoother now making it a bit worse.
I'm not spending hundreds on a damper either.
I have the OEM tyres on which I know makes it worse.
All ideas welcome.
Mike
steve172
Has thanked: 3 times
Re: 950 adv head wobble
Post by steve172 » Mon May 11, 2015 12:10 pm
Interesting thread, mine does the same.
I don't have a solution but will keep my eye on this thread.
zimtim
Has thanked: 556 times
Been thanked: 465 times
Post by zimtim » Mon May 11, 2015 12:13 pm
Nothing on mine. Really smooth to be honest I have no play in headstock at all. Running a Karoo 2 on the front with a mefo rear. (thumbs)
Agent Orange
Has thanked: 41 times
Been thanked: 26 times
Post by Agent Orange » Mon May 11, 2015 12:17 pm
Dial it out with suspension. Put more weight on the front by upping the preload. I have mine on sport setting plus a couple of clicks on the preload. It could be your tyres wearing etc
There is a septic tank (Yank) on YouTube that reckons it could be the rim tape out of place causing the front tyre not seating properly.
Come to think of it, mine shook it's head when I had my panniers on, so kicked myself for not adjusting the suspension before I set off. It then did it afterwards so I then dialled it out. Been set the same for years no probs. I just make sure I write down how much I alter the settings if going away etc.
jonny955
Post by jonny955 » Mon May 11, 2015 1:37 pm
Both my 990 Adventures did this, both when new or nearly new.
I had a fiddle with the settings but it made little difference. Only a brave man would take both his hands off the bars at those speeds! Of course, if you never did that it would not be an issues but how else can you text and check your satnav at the same time?
Jon
Mike54
Has thanked: 15 times
Been thanked: 90 times
Post by Mike54 » Mon May 11, 2015 4:32 pm
Set the sag correctly first of all. If the bike is not level either nose heavy or rear heavy it will do this, not just if it's on its arse.
check the fork alignment
check the front wheel is installed correctly ie are the forks binding
what tyre pressures are you running? if a lot below norm then up them obviously.
does it do it under braking only? if so check caliper and pads, do the pistons move ok
if all the above is ok, next step would be to change front tyre for something else
Richard Simpson
Post by Richard Simpson » Mon May 11, 2015 5:12 pm
I've never noticed this on mine
ktm Jules
Post by ktm Jules » Mon May 11, 2015 9:07 pm
Never had a problem on mine either. check tyre pressures and firm up suspension.
Mines always on sports settings even when i green lane.
Its trial n error as every ones riding style is different.
A steering damper can actually make the problem worse if not fitted and adjusted correctly.
Mike54
Post by Mike54 » Mon May 11, 2015 9:15 pm
this is the "septic" refrred to above. Happens to be the well respected jeff slaven.
the bike cant be on original tyres never taken off but check it out anyway and take a look at the wheel and rim strip
Agent Orange
Post by Agent Orange » Mon May 11, 2015 9:20 pm
Oops :whistle: just throwing up solutions Mike that's all.
Checked mine at the time all was fine BTW.
Users browsing this forum: Bing [Bot], Rallyx and 59 guests
