Cranking speed?
Oop North John
Has thanked: 154 times
Been thanked: 199 times
Re: Cranking speed?
Post by Oop North John »
Can you try putting some jump leads onto the battery when starting the bike so that you'll know if it's getting tired?
herman
Has thanked: 878 times
Been thanked: 632 times
Re: Cranking speed?
Post by herman »
Seems normal http://www.yamahasupertenere.com/index.php?topic=3718.0 still going to bung it on an optimate for a bit methinks
Nigel
Has thanked: 189 times
Been thanked: 102 times
Re: Cranking speed?
Post by Nigel »
Yep my new one is a bit like that, used to my 800gs turning over really quickly and the S10 seems laboured but always starts (thumbs)
Oop North John
Re: Cranking speed?
According to this review:
http://www.totalmotorcycle.com/motorcyc ... Tenere.htm
the S10 has an automatic decompression device, is yours working as it should?
herman
Re: Cranking speed?
Post by herman »
Oop North John wrote:According to this review:
Hopefully :S not like the KTM530 when it first came out with the decompresser manufactured in reverse :ohmy:
Geekay
Cranking speed?
Post by Geekay »
My 2013 model is the exact same. Kind of slow to turn when pressed. Always starts though.
yoda
Re: Cranking speed?
Post by yoda »
Mines a 2012, not using it much at the moment, started and ran it up sunday..cranks slow, same as always.
Chaos is the only camouflage that incompetence needs to operate at full capacity.
I dunno where that road goes, might as well go take a look anyway there's no where else i need to be right now.
spasm
Been thanked: 2 times
Re: Cranking speed?
Post by spasm »
mines 3 years old, same battery and has always sounded like it struggles to turn over. i wouldnt wanna be that little battery turning over a parralel 1200cc motor either. always starts though (thumbs)
i only need one wheel .......... the rear
