DRZ400 Cam Chain Tensioner
KTMChris
Has thanked: 3 times
Been thanked: 6 times
Post by KTMChris »
As some of you know I recently got myself a 2000 model DRZ400s.
What are your views on the manual/ automatic tensioners. I know they updated them in 2003/04.
Do I leave it alone, fit an upgraded one or go to a manual tensioner?
chrisinflight
Re: DRZ400 Cam Chain Tensioner
Post by chrisinflight »
Hi Chris,
I`m leaving mine as the camchain is quiet and it`s pretty low mileage. If your cam chain is quiet I would leave it for the time being and look at changing it for a manual one later. Your right about the upgrade circa 2003 :)
cheers,
2016 Beta 300rr- In the 2 stroke come-back club!
mr cc
Post by mr cc »
For the sake of twenty quid and a couple of minutes spannering, go for a manual one.
Peace of mind and all that!
Tom94
Post by Tom94 »
They can be silent and still fail if you bounce your bike off the limiter it can cause camchain to jump a tooth and detonate your engine
Sprockette
Post by Sprockette »
Definitely go for a MCCT. Not worth the risk and pretty easy to adjust:
Famous
Post by Famous »
If you have the later one leave it be
If you have the earlier one change it
chrisuk
Post by chrisuk »
Famous wrote:If you have the later one leave it be
+1
If it's an older silver automatic one, change it to the newer brown (2003-on) automatic one.
If you have or fit a manual one, make sure you know how/when to adjust it correctly.
I'm not aware of any newer brown automatic failures.
