Moroc bound
Re: Moroc bound
If the plug doesn't smell of fuel then its not getting fuel.sounds like it needs the carb stripping and cleaning,use a carb rebuild kit with new seals and gaskets to eliminate the leaking issue that you had I morroco (thumbs)
- Has thanked: 44 times
- Been thanked: 112 times
Re: Moroc bound
Well doen that man! (thumbs)Redmurty wrote:carb is booked in for a sonic clean and rebuild (thumbs)
cheers Spud
Simon
- Has thanked: 337 times
- Been thanked: 153 times
Re: Moroc bound
Mrs.... "have you sorted the bike yet"?
Me "no" :dry:
Mrs "do you know what's wrong and can you fix it "?
Me "not sure, had offers of help"
Mrs "do you know someone that can fix it?"
Me "yes" (thumbs)
Mrs "life's to short get it sorted, take it in" hmy:
had my orders, who am I to complain :whistle:
cheers Spud
Me "no" :dry:
Me "yes" (thumbs)
cheers Spud
Re: Moroc bound
part of the adventure mate (thumbs) where next Lee ?Lee Frost wrote:Hope you get it sorted soon Spud!
there's a pile of shite in the bottom of the petrol tank :side: so could just be the carb ? as you were behind me you saw how it just stopped after being refuelled. People keep asking me if it locked up I really don't think so.
You sorted your blow back out yet mate (thumbs) hot petrol on ya nuts in 40 plus degree heat :pinch:
cheers Spud
Re: Moroc bound
France and Switzerland next for me Spud, on the GS next month - but can't wait for another big off road trip.
The 690 has been cleared, just needs a service and new back tire. Put a different rack on the back so I can strap a bag down without covering the breather pipe on the rear tank so hoping that will solve the blow back problem!
Your bike just died, no lock-up, no drama, just stopped!
I'm sure it'll be up and running soon.
Re: Moroc bound
so here's what my mechanic mate and I think has gone on....
I decided to drain the oil today seeing as the head ect is going to come off. Only about 500 ml of oil came out of the bike so when they did the oil change in Moroc did they only fill the frame ?
So rocker cover off tonight and the cam looks ok but a spring had come off the auto de-compressor so the head is coming off next to assess the damage done to the bore valves and piston, so hopefully I will get away with a top end rebuild.
These engines must be absolutely bullet proof if they can survive that
need to check any play on the crank but it's not knocking, and sort out the de-compressor issue, can that be fixed without needing a new cam ?
cheers Spud
cheers Spud
- boboneleg
- Has thanked: 2363 times
- Been thanked: 1407 times
Re: Moroc bound
When you fill with oil through the filler on the top of the frame it makes it's way down into the engine eventually, there is a check screw at the bottom of the engine near the rear brake pedal, when it drips slowly out of there it's right.
Theses are tough old birds so don't panic Spud, if you do happen to need a crank I have a brand new one here.
If only 500 ml came out check the oil screen in the bottom of the frame, it is often overlooked and can cause a blockage. Put plenty of heat on the nut before you try to undo it as they can be a bitch to get out, that's why a lot of people overlook it.
cheers, Bob.
cheers, Bob.
one-legged adventurer
Re: Moroc bound
thanks Bob I'll go look for the screen and I might have to take you up on the offer for bits (thumbs)boboneleg wrote:When you fill with oil through the filler on the top of the frame it makes it's way down into the engine eventually, there is a check screw at the bottom of the engine near the rear brake pedal, when it drips slowly out of there it's right.
cheers, Bob.
I drained the frame, is that where the screen is ?
found the nut the one with the oil pipe on ?
cheers Spud
