GPX editing
Bikers and riding
herman
Has thanked: 878 times
Been thanked: 630 times
GPX editing
Post by herman » Tue Jan 15, 2019 3:15 pm
What program do you use? I mainly want to edit and erase parts of some tracks . Ease of use is of paramount importance. :roll:
WillS
Has thanked: 183 times
Been thanked: 94 times
Re: GPX editing
Post by WillS » Tue Jan 15, 2019 4:23 pm
For all mapping, creating and editing routes (gpx) I use BaseCamp.
Some don't like it, but once you are used to it it works well, and it's free.
I am sure many will give alternative options, and plenty of negative views on BaseCamp.
You just need to work with it. It gets better / easier over time.
herman
Re: GPX editing
Post by herman » Tue Jan 15, 2019 4:39 pm
Ta muchly, I use basecamp mainly for transferring and storing but I cannot erase part of a track with it , or not my version anyway . The last time I updated it kindly wiped out years of files so I am leaving what I have well alone now .
fatowl
Been thanked: 34 times
Re: GPX editing
Post by fatowl » Tue Jan 15, 2019 4:47 pm
Try mapsource. You can select the track and delete points in it.
You can also edit routes if required.
frenchy3
Has thanked: 282 times
Been thanked: 69 times
Re: GPX editing
Post by frenchy3 » Tue Jan 15, 2019 4:52 pm
I use bikehike.co.uk/course creator
I use viewranger too but do not like the automatic route generator. With bike hike you can click and edit individual points the save it as a track or route straight to the basecamp files.
Cone
Has thanked: 152 times
Been thanked: 246 times
Re: GPX editing
Post by Cone » Tue Jan 15, 2019 4:55 pm
Right click on the track and split it where you don’t want it then delete the bit you don’t want. Rename the bit you do want. That’s how I do it simples
WillS
Re: GPX editing
Post by WillS » Tue Jan 15, 2019 5:01 pm
You can download the new and older version of BaseCamp from Garmin.
Always use the backup regularly onto a spare disk. I used it recently when the PC crashed with Win 10 upgrade, lost everything that wasn't backed up!!
Before changing / editing a gpx file, I always make a copy and change that one, leaving the original if needed again.
Good luck.
simonw
Has thanked: 29 times
Been thanked: 67 times
Re: GPX editing
Post by simonw » Tue Jan 15, 2019 5:07 pm
I use https://www.myrouteapp.com, mostly. Very easy to use, and share with friends etc.
bikenav
Has thanked: 148 times
Been thanked: 90 times
Re: GPX editing
Post by bikenav » Tue Jan 15, 2019 5:11 pm
look at GPX Editor use it quite a bit myself. Interested in the problem you had with BC if I lost my files from it I would be more than a little peeved. Someone recommended to me once if your GPS unit is working well enough for you stay away from the updates maps or otherwise so have done and the same with the BC software actually safer? I dont know. I feel your pain.
Has thanked: 252 times
Been thanked: 422 times
Re: GPX editing
Post by Tramp » Tue Jan 15, 2019 5:47 pm
Basecamp works well...load the track into pc then chose either split track or the rubber and delete waypoints you dont need....
If you want some help just ask and ill pop over when its convenient :lol: ...
Always have a copy of original track saved :o ...and make sure the relevent map is open.
Users browsing this forum: fatowl and 50 guests
