Photography : Using Fill Flash
Thought your camera’s flash was for use only in dark conditions? Think again.
Words and Images: Simon Thomas
Your camera’s flash is only for shooting in dark conditions, right? Wrong!
So many people miss the opportunity to capture stunning images because of difficult lighting situations, like shooting in the direction of the sun or towards very strong backlighting. Both of these conditions can ruin a potentially powerful image.
But here’s the ‘heads-up’, most cameras provide you with the tools to combat tough lighting conditions, it’s just many users don’t know how to use them. Using your camera’s detachable or built-in flash can greatly improve your chances of snagging that once in a lifetime shot, in spite of that awful sun glare or overpoweringly bright backlight.
By the book
If you read any fancy photographic book or magazine you’ll come across ‘fill light’. “What’s fill light?” Well, I’m glad you asked. It’s just photo speak for using your camera’s flash to brighten a foreground element of your photo that would normally be dark or even silhouetted because of bright backlight conditions.
If you’ve ever seen a photographer using his or her flash in the daytime (you’ll see this a lot at weddings) or in a bright situation, well, now you know why.
Flogging a Dead Horse
The photo in this masterclass was shot directly into the sun, with my bike parked up on the Dalton Highway in Alaska, as we rode south from Deadhorse. I wanted a shot that showed my bike and my bags and gear from a different angle and totally covered in the mud, crap and grime of the Haul Road (Dalton Highway).
You’re Right, Your Camera’s Wrong
The reason the photo works is really only because I set up my flash (or speed-light as Nikon calls it) to trigger when I shot the image. On many cameras, this is called ‘force flash’, because you’re forcing the flash to fire even when your camera thinks it isn’t needed.
In my camera’s menu, I selected a profile that offered my low contrast settings and I bumped up the saturation. Again, it’ll take you a few minutes, but hunt around in your camera’s settings and you’ll probably find these options are available to you. Worst case scenario, go and find a tutorial on your camera’s settings on YouTube.
Get Flashy
The flash though is the key. It allowed me to manually expose the shot in order to capture some of the details in the clouds and landscape in the very bright background but, crucially, also the detail and texture of my bike in the foreground. Try this for yourself.
This technique works equally as well for shooting portraits or any other scene where you’re forced to shoot in the direction of bright light.
