garyboy
Has thanked: 2282 times
Been thanked: 992 times
Post by garyboy »
Imagef by gary boy, on Flickr
completed my crf250rally clutch yesterday, but when i came to test it, the rear tyre was horrendously thumpy-bouncy ... turns out it was the mousse flattened at the bottom from standing too long. Took for a tyre warming blast and it came back to normal .. phew.
Took it for a little local run .. all fine .
Left the side fairings off as i aim to fit my YSS shock soon (ish).
Hugh
Has thanked: 889 times
Been thanked: 932 times
Post by Hugh »
Greetings, fitted Christmas present handlebar muffs to the Pampera, nothing major nor time consuming but a big help for my hands. TTFN Hugh.
Has thanked: 1427 times
Been thanked: 1677 times
Do they go over the handguards, Hugh?
Hugh
Post by Hugh »
Greetings Richard,
They are the black polyester fleece lined of the available two types and just slide straight over the hand protectors. The mirror stems can easily be accommodated with a camping eyelet if needed.
A little bit tight fitting around the switches but they do give a little clearance with use. I have an eyelet fitted at the cable end for a shoe lace tie as there can be a little bit of a draft depending upon master cylinder sizes; cables; etc :lol:
Easily removed for trials events and then put back on for the ride home. Great accessory for my needs and combined with heated grips they are easy to use.
